Rheem Hybrid
  • Rheem Hybrid
    These have been discussed in the past. Wondering if anyone has actually installed or serviced one?
    I have a job to look at where this might be a possibility for an interested homeowner. Replacement in an attic. Problem is that the attic is a hideaway ladder type and I'm wondering how often filters & settings have to be dealt with.
    Thanks.
    Re: Rheem Hybrid
    Keep in mind it needs 1,000 cu/ft to breathe and there is a condensation line that you need to run into something or outside. The filter is washable and its lifespan depends on air quality and usage. There a good item and have a great warranty. I installed one in a garage. Keep in mind the height difference if you are replacing a 50 gal elec with a 50gal hybrid.
    Ray
    www.mauiplumbinginc.com
      Re: Rheem Hybrid
      So then putting one in an attic sound like a huge no no.....?
      Derek
        Re: Rheem Hybrid
        I don't know why it would be a no-no. The condensate drain shouldn't be too hard to get out an eve possibly and down to the ground. And 1,000 cu./ft. isn't that hard to get in many attics. So you would be pulling heat and humidity out of the attic as I understand it to make hot water.
        My big concern is if someone would have to go up there and clean a filter every three months.
        P.S. I still think the traditional "less efficient" heaters we've all had for years are best. K.I.S.S.
        Thanks.
