Kohler Trend
  • Kohler Trend
    I was going to get me an impact wrench to get apart a Kohler Trend tub valve. You know they so hard to get apart if you dont have one. Your regular tub wrenches don't usually work.
    Re: Kohler Trend
    A 15/16 deep impact works very well on Trend tub valve stems.
    The problem usually encountered is a lack of clearance around the stem
    to allow for the use of thick walled sockets. On a tile wall, this can
    be a challenge. I use this shop made tool fashioned from a 1 3/4 carbide
    hole saw drilled and tapped to fit a long, threaded escutcheon adapter
    which, being hollow, fits over the protruding stem and centers the saw
    for a cutting a nice, neat hole that can be easily covered by the trim ring.
    A piece of round steel stock is brazed to the other end for chucking into a drill.
      Re: Kohler Trend
      nice work jim.
      mark and i have a discontinued tool called "expose a valve"
      prety much does what you's does, but an adjustablle depth stop and centering bushings. much more commercail carbide holesaw body.
      very nice design on your end jim.
        Re: Kohler Trend
        Actually, the kudos go to another guy in our shop.
        His name in Rick, also. He doesn't participate on the
        forum but I know he will read this.
        Old style valve stem repairs are becoming rarer.
        That tool is over 15 yrs. old and while the hole saw is getting
        a little dull, it will still cut tile.
          Re: Kohler Trend
          I love it. thank you
