residential fire sprinkler
  • residential fire sprinkler
    If you were installing a sprinkler system in your own home, given the available material. what would you choose?
    I've been kicking the idea around for a few years now, and I go back and forth on it.
    pex would obviously be the easiest, but I don't really want to use it in my home.
    CPVC seems nice and easy to install. and making the runs go in would be cake.
    Steel pipe Seems the most durable, but it's also the most expensive and the most difficult to install in a retrofit scenario.
    Figuring on a preblended glycol mix protected by an RPZ in my mechanical closet before it stubs up into the attic.
    Re: residential fire sprinkler
    Go to Uponors web site.
      the system of the future that would be my choice is a combination fire sprinkler and potable system. all the heads are piped in a loop with the domestic fixtures using pex or cpvc.
      this allows for the plumber to do the install and because it's all potable water, there's no stagnant water sitting in the system. plus there's no real shut down of the system, without affecting the rest of your domestic fixtures. basically it prevents a person from shutting off the sprinklers unless doing maintenance.
        my problem with the combination systems is that i'm wanting to install the heads in the ceiling of my ranch home. So I need to either build a dry system, which would be a pita for my level of know how. or I need an antifreeze in the line. If I went with in wall heads I'd have a lot of sheetrock repair to do, which I despise.
          not getting to scientific on your system, but if you installed the piping protected by a dual check valve and then pressurized the system with compressed air at a higher pressure than the potable water. the checks will keep the air in the system until a head is triggered.
          not that complicated, and a simple pressure gage is all that's needed to monitor the charge.
            ....and you know, that makes perfect sense. thank you rick.
              We don't do sprinkler systems, but the guys here are using an orange pvc type pipe, and I don't know what it is.
                cpvc, for fire sprinklers.
                  Originally posted by flux View Post
                  we don't do sprinkler systems, but the guys here are using an orange pvc type pipe, and i don't know what it is.
                  It is called Blazemaster cpvc special for in house sprinkler systems
                  the air system Rick posted is the way to go that's what nfpa 13d calls for in cold or refrigerated rooms
                  the air can't freeze and if a sprinklers head pops it only takes a few seconds for the air to bleed out and the water
                  to start running, !
                  JERRYMAC
                  E-MAILJERRYMAC777@GMAIL.COM
                  FIRE SPRINKLER CONTRACTOR,
                  SINCE JAN. 1989
