Tape, and dope
  • Tape, and dope
    J
    Re: Tape, and dope
    I have had no problem with using just rector seal #5.
      Re: Tape, and dope
      4 tight raps tape and dope,for Me. With this combo You can back of 1/4 turn and never have a gas leak.
        Re: Tape, and dope
        Thé bit of gas iv done we always just used permetex but id think tape and dope is fail proof thats what we did when i was sprinkler fitting.
          Re: Tape, and dope
          Tape and dope and you are good to go. I would use Blue Monster tape and Gasoila dope.
            Re: Tape, and dope
            k
              Re: Tape, and dope
              Originally posted by TheMaster
              Your boss is right. Use the time that your putting the tape on instead to check for proper threads. Using both is really a waste of time and material. It can cause inexperienced workers to overtighten the joint stressing it and breaking it later.
              I agree. Use a good quality pipe dope only- without tape. Thread quality is very important especially in the larger pipe sizes. I only use tape when connecting directly to the appliance just so I don't get pipe dope in the screen.
              Don't try to cut costs using a less expensive fitting supplier. There's a lot of crappy foreign products on the market these days. The money you save up front won't pay off if you have to change one 90 in the middle of the line because it cracked.
                Re: Tape, and dope
                I'm in the Rector Seal #5 camp also. Tape is for homeowners and apprentices
                  Re: Tape, and dope
                  No tape on gas piping!!!!! I like BlueBlock or Rectum Seal.
                    Re: Tape, and dope
                    I say dope as well....have never used tape on gas fittings...seems like a waste of time to me. A good dope will give you a good seal.
                    Ideal Plumbing
                      Re: Tape, and dope
                      I've used just dope, just teflon tape and a combo of both on pipe up to 1.25". Good threads is all that was important. I like teflon tape because I don't make a huge mess with it, but mostly I use pipe dope because it is always in the toolbox.
                      You know when the pipe is going together bad! Take it apart and fix what ever is causing the fitting to not feel right.
                        Re: Tape, and dope
                        On lines 2-1/2" and above we've had good luck with Superdope http://www.argco.com/store/main.aspx...l&item=1010086
                          Re: Tape, and dope
                          I like tape and blue block. I learned this from a great book written by a Berkley plumber. Plumbing a house by Peter Hemp.
                          Many experienced plumbers have written good reviews on His book. Works for Me and as Peter says " You can back off a fitting and never have a leak with this way ".
                            Re: Tape, and dope
ID:	626250 No need for anything else. Tried and true. Rectorseal # 5.
                            Will Rogers Plumbing
                            Moore, Oklahoma
                            405) 323-2852
                            www.willrogersplumbing.com
                              Re: Tape, and dope
                              Teflon tape isn't allowed on gas piping in our state.
                              It's all Rectorseal #5 for me as well.
