Borzit boring Machine
  • Borzit boring Machine
    I broke the Hex shaft. Called Jim Hill the owner,inventor,and actually got to pick His Brain. He is over nighting a new 440 heat treated shaft . 4 times stronger than the original. He walked Me through the process. Great Service. Of course I could have just sent it back but I'm an impatient Irishman. I was way to rough in hard dry clay!
    Re: Borzit boring Machine
    that's why i like my water booring setup. no drilling. just high pressure water jetting.
      That May be true Rick, but some of Us out here don't have Your tool allowance !
      For $199 a guy can bore under a slab or griveway for pipe. NOT BAD! SOLID CONSTRUCTION !
        but you do own a pressure washer?
        all you need is a hose with pipe and a nozzle connected to your pressure washer.
          What I like about the Borzit is it only uses a small amount of water,and spoils [ dirt] is compressed to the sides of the drilled hole. No dirt comes out! I don't want cavitation under a slab or driveway. Also I'm working pretty clean with only a small amount of water.
            believe it or not. the jetter uses less water than the borzit.
            remember i have them both and use them both. even have 8 stitches in my brow to prove it
            you could easily water bore then pull back with the borzit cutter of choice.
            next dinner, i'll make you a drawing
              I like my borzit! I have never really bonded with my water boring tool, everytime I use it the ground has so many rocks (big ones) That it deflects and tries to come to the surface. So Now I use the borzit for easy quick jobs and my air mole for anything longer.
              Seattle Drain Service
                If You break a Hex shaft ,they screw out! I drilled and used an e z out. Right hand thread. New hexes are 4 times stronger.
