Water pressure
  • Water pressure
    Working on a house that has a pressure assist toilet that just isnt flushing right. I checked the water pressure and it was around twenty pounds. In believe this is the problem but not sure the best way to fix it. Im pretty fond of pressure assist toilets so really dont want to change it out usually dont have any problems with them. what would be best way to increase the pressure to the house? It has a one inch pvc line coming in off of city water.
    Re: Water pressure
    Need to check to see if there is a faulty pressure reducing valve somewhere....
    Derek
      Re: Water pressure
      I believe 20 psi is the minimum pressure for pressure assist water closets. Any more most Jurisdictions are requiring 40 psi minimum to a home. If you are trying to save the pressure assist water closet by increasing the pressure I would rethink saving the water closet.
        Re: Water pressure
        Well you gotta find out if there's anything in the house that could be reducing the pressure and of course a call to the water district will give you how much pressure is at the street both static and normal demand but if the pressure is only 20 lbs, you may want to consider a boost pump and tank set.
          Re: Water pressure
          Grundfos makes a handy little booster pump that doesn't need a tank, I want to say it runs about 600 bucks, if you use one make sure you install a PRV after it, It'll run 110-120 psi
            Re: Water pressure
            I believe Sloan calls for a minimum pressure of 35 PSI for the Flushmate, so you need to fix that
              Re: Water pressure
              Well that was my suggestion was to either replace toilet or increase pressure to house but this is a beautiful home with four bathrooms overlooking the lake that is vacant right now owner rents it out but cant imagine anyone being happy with that kind of pressure.
                Re: Water pressure
                The 35 PSI minimum is only for the one gallon flush WC. The 1.6 and the 1.28 gallon flush is 20 PSI minimum.
                  Re: Water pressure
                  So the pressure is 20 psi, and no one is complaining about that in itself? I bet taking a shower in that house is like getting pissed on by a drunk guy.
                    Re: Water pressure
                    When was the last time you got pissed on by a drunk guy? WTF thats a strange thing to say.
                      Re: Water pressure
                      4 bathrooms and 20 psi? This toilet cant be the first complaint at this house. Is it?
                      26+6=1
                        Re: Water pressure
                        Sounds as if you might have been in the Navy. I know I saw some wild stuff when I was in.
                          Re: Water pressure
                          Even in Arkansas the city should have more pressure than 20 lb
                          What do they say about it
