internal brass tube cutter
  • internal brass tube cutter
    I've been reuested to build, or find an internal pipe cutter to cut 4 1/4 ins dia brass pipe. This has to be done 60 feet down a bore . is such a tool available , or any ideas & suggestions. Ta Allan
    Can't think of anything off hand that would work. Have you thought about contacting Tri-Tool to see if they have anything?
    4-1/4" Brass pipe, what's that used on?
      Wheeler/Rex Makes an internal pipe cutter for PVC shed 40 and PVC shed 80 pipe. The 4" model has a carbide tipped blade which may work cutting the brass pipe. I would suggest contacting Wheeler/Rex's engineering Dept to see if they have a heavier spring or possibly another tool made for just your application. The tool I am referring to has a 12" shaft which could be extended to meet your 60' depth requirement.
      Hope this helps you!
      Dave
      Plumber 122
