block and tackle for lifting W.HS.
  • block and tackle for lifting W.HS.
    Thanks Rick, remembered Your 1 man rig. Ground a slot in a 3/4" end cap, welded in a
    heavy metal ring. Made up a block and tackle. Works great!
    Re: block and tackle for lifting W.HS.
    interesting. i just drilled a hole and installed a lifting rated eye ring/ hook. i have 3/4'' and 1'' for the 75 gal. on a 100 gallon i have a set of 2 x 1.5'' tees and then slide a pipe through the center of the twin 2'' tees. this way the lift stays dead center from the hot and cold. for the big ones i use an electric winch so i can free up both hands to position the heater.
    even have used it for a 36'' x 36'' traffic weight solid sump pit cover.
    so now you know how to get it up
    http://www.ridgidforum.com/forum/t20570/
      Two tees is a great idea,thanks
        Rick, could You post a picture of Your set up again ? I'm thinking of reeving one more pulley .Thanks Tool
          he has a link in the first post to the original post of his with pictures or as least some pictures, here is original post, pictures lower in the post as well,
