Drum Traps
  • Drum Traps
    Anyone replace these? Almost every basement around here has or had one for a bathtub trap and they are rotting out. I cut them out with the sawzall replacing as much drain as I can that's exposed replacing it with a pvc trap and pipe. I get one or two of these a week.
    Most of the time they come off the tub waste and overflow but sometimes being over 50 years old I end up replacing the W/O too.
    Also make sure you check the inside of the drum traps, treasures can be found inside.
    This isn't one of my pictures but it's a good picture of a 1950's drum trap under a bathtub.
    http://0.tqn.com/w/experts/Plumbing-...-Trap-Vent.jpg
    Re: Drum Traps
    Isn't it upside down?
      Re: Drum Traps
      Instead of putting that PVC cap on there, I would have just cut it all out and replaced it. what a waste of a pvc cap.
      Plumber Raleigh,Plumber Cary,Plumber Apex ,Plumber Apex, Plumber Morrisville,Plumber Durham, ,Plumber Holly Springs,Plumber Chapel Hill,Sump Pump Raleigh
        Re: Drum Traps
        Most all of them I see are installed that way with the clean out on the down side. That's why I liked that picture, it's exactly what we have around here. Must have been the same plumbing company doing all of them. The homes that have them were built from around 1952 to 59, originally they have cheap metal caps that rot out.
          Re: Drum Traps
          LOL I had the same feeling when I saw that picture. Also the galvy water lines, just want at them!!!
            Re: Drum Traps
            We still have a ton of drum traps around here.
              Re: Drum Traps
              Drum traps were required on all lavs installed in Maine up till about 10 years ago, so yes, we see a whole lot of them.
                Re: Drum Traps
                I was curious because we have them everywhere here. When I was in No. Ca. I never saw one.
                  Re: Drum Traps
                  I bet I have close to a ton of lead drum traps stacked behind the shop.
                    Re: Drum Traps
                    When I was in So Cal, never ran into one. Guess I will out here now and they will get replaced. I did see them in plenty of UPC code pctures under Illegal
                      Re: Drum Traps
                      Yea they're illegal here in Mn now too. I've only seen them on tubs. One of my most favorite service calls to get. Sawzall, no hub band, pvc trap & pipe etc. I usually make my first cut on the tub side of the trap as to not disturb the W/O too much. Then most of the time I'll just turn out the 1 1/2" fine thread tail piece from the W/O and start new from there.
                        Re: Drum Traps
                        Drum traps are all over here
                        Rod
                        http://unclognh.com
                          Re: Drum Traps
                          We have alot of drum traps here in older homes also. Just cut them out and replace. But thats the way I have seen them also with the cap down.
                            Re: Drum Traps
                            only time I see the cap pointing up is if they're set flush with the finished floor.
                              Re: Drum Traps
                              I just cut one out today that was cracked. The plugs can be up or down. They came in a zillion configurations (side inlet-side outlet, side inlet top outlet, side-bottom, etc.). If the drum trap ended up under a mud set tile floor, you're not going to put the clean out facing up....you're going to face it down into the basement. I see a lot of them. I cut them out when I can, sometimes rod them if they are buried in the wall or floor (more often use the Water Ram though).
                              Believe it or not Home Depot and Menard's sell CI and PVC drum traps......the PVC ones swivel 360 degrees, absolute garbage and they're made by NIBCO to boot!
                              see page 29:
                              http://www.nibco.com/assets/plasticfit.pdf
