Toilet arm/flange repair
  • Toilet arm/flange repair
    123
    Re: Toilet arm/flange repair
    How much?
      My guess is about $500.00.....
      Looks good...did your hand shake with the primer or what....lol....
      And it looks like tile over tile?
      Derek
        Originally posted by TheMaster
        Yes thats tile over tile. I almost dropped my can of primer...yes I was in a hurry we had some bad weather coming. More bad weather on the way right now.
        Jobsite conditions dictated the price. Had to park 1/2 block down the street and haul everything in. Commercial building. Plus I hafta make a second trip after the tile is set to install the flange and toilet.
        Makes sense on the pricing then.....fair enough....and it does look like wall tile....gotta say thou never seen tile over tile too much around here....
        Derek
          Tile over tile is fine to do as long as the original tile is in good shape. All that needs to be done is a quick sratch on the original tile with a grinder before applying the next layer of tile.
          Will Rogers Plumbing
          Moore, Oklahoma
          405) 323-2852
          www.willrogersplumbing.com
            I'm still trying to see how the connection was made from C.I. TO plastic. Pack in lead wool maybe ?
              Probubly a no hub coupling.
              Moore, Oklahoma
              405) 323-2852
                Next time go easy on the primer.
                Moore, Oklahoma
                405) 323-2852
                  You dont see the no-hub band? They fit plastic and the cast iron perfect. Some dont but I got a case of them a couple years ago that fit perfect.
                  I don't use that brand. Now I see the clamp screws. The rubber shines like abs.
                    Nice job TM.
                      I'm not going to say anything about the primer, cause it was already said.
                      $1,200.00 is right there in our ball park up here in Pa.
                      Lastly, thank god we don't have many houses on slabs here.
                      Nice job.
                        We call them Husky Bands here. It's like an extra heavy No-Hub coupling.
                        were you supposed to have a PVC No-Hub adapter to join the cast iron to PVC?
                          From the picture I assume the bend was cast iron and not lead. Why didn't you just lead in a new ring?
                            big sections of the south, they give you a blank stare when you ask for a pvc no hub adapter. So no surprise that he didn't install one.
                            I love the no hub bands with 4 clamps, tough little guys.
                            Looks like a good install, miserable work.
                              I dont even know the name brand of those couplings but I tell ya,they are strong. The hubs are 1.5" deep with two bands on each side.
                              I did use them several years ago [full metal band,4 bands] in S.F., THE INSP. hadn't seen a 4 banded mission and liked them,who wouldn't?
