Angle stops
  • Angle stops
    Any time I'm changing out a fixture I install new 1/4 turn angle stops. Where I live and work ,It's 5/8"x3/8" compression stops. Do You prefer 5/8"x1/2" ? Thank You
    Re: Angle stops
    Where I live, it's 99.99% 5/8"x3/8". Can't recall a fixture needing the 1/2". Maybe a hospital fixture or two.
    Pretty much prefer and only need the 3/8".
      Re: Angle stops
      99% 3/8" I'm not sure my little supply house has the 1/4 turn in 5/8"x 1/2", guess I better look in the morning...
        Re: Angle stops
        tool, the west coast has always been 1/2'' slip joint connections. the rest of the country is 3/8''.
        now with the lead free requirements, seems like all the faucets are 3/8'' connectors.
        also 3/8'' compression is less expensive than 1/2'' slip joint.
        please don't tell me you solder on your stops
          Re: Angle stops
          I solder stops on and I am proud of it.
            Re: Angle stops
            Compression only here are u saying sweat stops or mip by fip stops?
              Re: Angle stops
              sweat stops, when there is copper.
                Re: Angle stops
                That's weird how the West Coast is compression stops...East Coast is sweat stops. (You're with us Ron..lol)
                Like I said before, and I know this will fire up the West Coast guys, if I was to install a compression stop I would be called a "Hack" here. lol
                If it's copper...it better be sweated on around here.
                  Re: Angle stops
                  I think compression stops are fine for the most part. Put on my share. Just lowered the percentage of problems with sweat for whatever reason.
                  What I don't get is the 1/2" supply out?
                    Re: Angle stops
                    I always keep a set of compression stops for emergencies only.
                    I agree with you on the 1/2" supply out!
                      Re: Angle stops
                      it's not 1/2'' od compression. the kohler 1 pc. required 1/2'' od for a proper fill and flush on the 1 pc. toilets.
                      it's 1/2'' slip joint. the same connection that is on the shanks of faucet and 4'' center sets.
                      so the flex connectors are 1/2'' x 1/2'' x 12'',16''or 20''
                      3/8'' is the most common size across the nation. 1/2'' slip joint is the most common out here.
                      but like i said, the 3/8'' is less costly and will soon be a west coast thing too as faucets are now coming with 3/8'' connectors built in.
                        Re: Angle stops
                        For the record, where I come from...
                        I've never actually seen a sweat supply stop in a home, and copper is ubiquitous here too...
                          Re: Angle stops
                          No sweat Rick ! You're a good teacher!
                            Re: Angle stops
                            TM and Rick is right...there were some Kohler toilets with 1/2" supply's maybe a Case...there are some Kohler lavatory faucets here from the 50's and 60's that have 1/2" supply but are easy to recognize by the cross handle on the stop.....but mostly sweat stops here that will get converted to compression in 1/2" X 3/8"...
                            Derek
                              Re: Angle stops
                              All of you have it wrong. West coast and East Coast. Here in the Midwest we PROPRESS all of our stops on!
                              No kidding, I do! Though I use a 1/2"FIP x 3/8 stop, I use a Propress 1/2" male adapter into the stop. Instead of screwing around trying to tighten a compression nut under a sink or trying to sweat it on while trying to breathe I just press a button and it's done. Not all will have enough copper sticking out to cut off the old stop but I would say 90% do. I also screw on my supply before I attach the angle stop to the pipe, saves a lot of time and effort.
                              Ridgid thought it was cool, they sent me a box of hand tools for my idea! I wanted a new PP tool but they wouldn't go for that.
