Troubleshooting Test
    Re: Troubleshooting Test
    Are you sure this is a stubout and not a premade hammer arrestor?
      Do you want an azz-whoopin'?
        Come on JC are you really sure it wasn't a hammer arrestor? This is unheard of!
          Now you're on the list.
          Could be. I have no idea. . Just know what I ran into. Anyone got a picture of a Hammer Arrestor with a spun-weld copper end?
            Find the guy who installed it, and kick his a$$.
            I did it.
            The guy who hired me was not paying,he was already in to me for two grand on the ground work.Sorry J.C. I thought the cheap P.O.S. would try and set the finish himself.Instead he lost the house in foreclosure.Now your guy's got it.
              Originally posted by TheMaster
              I might. The computer it might be on has a bad power supply so I cant turn it on. I know for a fact they use to be made,I did a remodel a couple years ago and found some buried in the wall. Air chambers.....some people make them with a cap.
              I've seen all kinds made in the field (useless) and manufactured. I don't recall one with the bullet end though. Doesn't make sense that it could end up as a stubout.
                are you saying that the moen spout doesn't fit 1/2'' / 5/8'' od copper?
                call moen and ask them wtf?
                do they make bullets that are 3/4'' od for hvac?
                newer crecent wrenches are laser engraved or just a set of open end wrenches will get you pretty close to the proper size.
                how about a swedging tool?
                • #23
                  I first thought WTH? I've lost my mind.
                  Then I thought, HVAC tube? Bullet end? Just as you did. But I have no idea.
                  Then I thought of the things I didn't have with me as I was just going to put trim on. As always, you need a tractor trailer of stuff to put a toilet handle on.
                  The spout will work fine on normal 5/8" copper.
                  • #24
                    As long as it comes with fried chicken and waffles.
                    • #25
                      Let's just skip the fight.
                      • #26
                        How much bigger is it how thick was the wall could you sand cloth it down enough to get a coupling on it ?
                        • #27
                          My mom's house has a water hammer arrester with a bullet end. It has a 3/4" diameter and is about 30 years old.
                          • #28
                            Looks like it froze to me.
                            I was told there is no way other than cutting out the swole copper and soldering in new to correct that issue. Ran into some on a 2 story a few months back and man that stuff will piss ya off. I think propress fittings are a leeeetle bit larger inside than reg copper fittings though. Seemed to be able to shove one on when we couldn't a reg coupling if I remember right.
                            • #29
                              ? Know Nothing about propress could you sauder it on to the stubout if needed?
