Orangeburg
  • Orangeburg
    Don't know if this is worth putting up for any interest. Just another day.
    Orangeburg. Been giving problems. City replaced connection and cleanout at street. Backpitched. Replaced it again. Still problems. Called us. Found the pipe typically oblonged. And the real problem is that the city put a brick under the connection at the cleanout/street connection to support the connection and try to prevent the backpitch again. Not good.
    Re: Orangeburg
    J.C. do they not require a bed of stone down there for your sewer installations?
    Here we have to have a bed of stone down, and backfill and tamp in 6" lifts.
    But that's the first time I've ever seen Orangburg, thanks for posting.
      Re: Orangeburg
      No. We are not required to bed anything in stone. Stone bedding and tamping does sound better to me. Or maybe rock dust.
      However, I have to say we don't see any long-term issues with PVC installed this way.
      At least in this area.
        Re: Orangeburg
        Still run into it down here, occasionally.
        At least down here we don't lay our pipe that deep, unless you want
        to be in the water table. Nice job, BTW. I'm intrigued with the
        twin clean outs. Never seen that.
          Re: Orangeburg
          I'm going to guess the clean outs facing eachother enables one the run a drain cleaning machine from outside so you can get the the main cleanout in the house without dragging the equipment inside, same as going the other way to the street. I am guessing this makes clearing a main a breeze... just guessing?
            Re: Orangeburg
            Honestly, we don't always do it. But in this situation, we did.
            One person lives there and often travels. The bathroom that gets the main use is about 50'-60' under the house. It's plumbed in 4". And the most accessible cleanout is a C.O. Tee just before it exits the house. Plus, he's had multiple stoppages. Add it all up, and since I had everything open I wanted to put the sewer/plumbing in a position that it could be serviced at this area if a problem arises again. Hope no-one ever needs them.
              Re: Orangeburg
              Twin clean-outs should be mandatory IMO.
              We have a ritzy development in my area that was just built a few years ago. These homes are huge, and mostly millionaires are living in there, and NOT 1 clean-out outside!! The majority have their basements finished, so forget pulling the clean-out plug on the main in the basement. I would think about pulling a toilet, but most have marble floors installed, and that scares me.
              I had 1 blocked main so far in this development (soft blockage), and with the weight of the water in the system, I shook the 4" PVC a little bit and WHOOOSH..it drained. After the call I went up to the township building and asked why there are no clean-outs installed outside, and was told "it's not required". WTF?
              I guess someone there doesn't know how to read a code book.
                Re: Orangeburg
                I've never seen an out door cleanout here. Maybe due to weather conditions in the winter?
                  Re: Orangeburg
                  Bet you've never seen them sewers so shallow either! LOL, Around here we average 8 feet down.
                    Re: Orangeburg
                    My Orangeburg sewer is only 43-years old. I wonder how many more years I can get out of it?
                      Re: Orangeburg
                      Impossible to say. If it stays round and goes down, I guess it could last as long as you need it too.
                        Re: Orangeburg
                        Great job JC, perfect 2 way cleanout!
                        Plumber Raleigh,Plumber Cary,Plumber Apex ,Plumber Apex, Plumber Morrisville,Plumber Durham, ,Plumber Holly Springs,Plumber Chapel Hill,Sump Pump Raleigh
                          Re: Orangeburg
                          I can count the times i had to pull a com to clean a sewer on 2 hands
                          Most houses here have two cl outs or one 2 way
                          If its deep the twins are the best to know witch way your going
                            Re: Orangeburg
                            Anyone ever see Orangeburg that was never installed, buried, or had a very short service life and is like new?
                            It kind of looks and feels like PVC, or actually more like ABS since it's black. Totally different looking then what we dig up.
                            I know in some areas they still lay Clay pipe. Please tell me this not true with Orangeburg.
                              Re: Orangeburg
                              Mark i still dig some Ob up that is still surprisingly round , its usually 2ft or better deep
                              keep a eye on the grandkids, avoid big partys,
                              tic tic
