? schedule 80 ball valves
  • ? schedule 80 ball valves
    I'm using ipex sch eighty ball valves with unions either side on this sewsge press im attempting to plum, its been interesting anyways just curious why do these ball valves have a dirrectional flow arrow on them this may be a very rookie question but im just not sure why a ball valve wouldnt close either way?? I ran into this before luckily theres unions both sides which makes changing them quite easy. Any clarification would be greatly appreciated thanks seanny
    Re: ? schedule 80 ball valves
Name:	camera sept 2011 913.jpg
ID:	626431Click image for larger version
Name:	camera sept 2011 923.jpg
ID:	626430Click image for larger version
Name:	camera sept 2011 920.jpg
ID:	626429Click image for larger version
Name:	camera sept 2011 919.jpg
ID:	626428Click image for larger version
Name:	camera sept 2011 918.jpg
    well this is it the mighty press that deals with the solids the sewage treatment plant cant deal with it injects polymeir into the sh1t and presses it into a solid pancake of crap so they can backfill i. any positive critism welcomed.. thanks seanny.
Name:	camera sept 2011 917.jpg
ID:	626432 oops forgot one,
        the only thin i can think of is there is an adjustment on one side of the ball valve ,you put that side on the non pressure side so you can take apart the union and adjust the nut that rests on the ball
          I think Hawk is right....its like a built in check valve....
          Derek
            Took one apart today both sides appear the same but if there in backwards they dont hold back the pressure ? Think i might call the manufacturer?
              If i'm thinking about it right, the ball rests in a seat, and if you have it facing the right direction the supply side pressure would apply force on the ball to press it into it's seat when the valve is closed. if you reverse it you could end up with a slight seepage around the ball because it is being forced Out of the seat.
