Hacktown revisited
  • Hacktown revisited
    I thought I would throw a Hacktown post together for JC:-)
    Yup, The old Radiator hose Sink Drain... The house flipper could not understand why I was taking a pic of this gem:-)
    PVC gasline under the newly enclosed deck DOH!!!
    Plumber says "Framer Dude this toilet stub is supposed to be centered in this opening"
    Framer says " Cant you use one of those crooked flange things to center it up we busted this layout by 6"
    Plumber chuckles and writes GC an estimate to move the stub to cover his framers boo boo... Framer moved the walls:-)
    I could not resist, I had to answer!!!! Internet optimization from Bangladesh for the win!!!!
    Re: Hacktown revisited
    Sweet....very classy stuff....real pro's.....
    Derek
      Was there anything wrapped around the stub out for the toilet or do you usually stub w/ 4" and put the flange inside?
        Add this one ...
        Cleanout 12" below grade pipe just stuck in ...
          Well here's my contribution to this one.....
          Derek
            Yes, it is just under the mud a little:-)
              Not bad for Oklahoma
              Will Rogers Plumbing
              Moore, Oklahoma
              405) 323-2852
              www.willrogersplumbing.com
                How about a hack town calender ?
                  With all the Hack jobs we got here we could do a 365 daily desktop...A decade full.They never stop coming in.
                    I'll post my contributions here too.
                    This one isn't so much hack as WTF? Yes, i'm sure you'd like me to find out why you have no hot water, but How am I supposed to get there from here?
                    These two are the same job, Local convenience store called because their toilet was leaking. I get there, see a moldy caulk line around the base, and figure "wax ring, this will be quick."
                    I pull the toilet, Well crap, that wax ring is so new it's still in the plastic!
                    Oh, it gets better, Flanges are over rated. if one breaks off apparently you can just use anchor bolts to hold the stool down.
Name:	camera sept 2011 410.jpg
ID:	15548how not to vent a toilet yes a 1'' poy line duct taped in a inch and a half 90 ranunderground into the neighboursgarden..not joking tought this w kinda funny.. seanny
                      • Trent2
                        Trent2 commented
                        Editing a comment
                        Thanks for the laugh!
                      LOL, when he cut the pipes off the water stopped on its own! SKILL!
                        Yeah I stub up with 4" and glue a flange into that then anchor to concrete.
                          Gotta ask Josh, how big of houses are you plumbing. And why are you anchoring your flange to the slab?
                            So the ring of the flange doesn't give and let the toilet move. I have seen lots of plastic flanges that are either bowed or broken.
