Can I exhaust My dryer into hot water chimney ????
  • Can I exhaust My dryer into hot water chimney ????
    Have a neighbor,great Guy,and customer. That was the question yesterday. I did some
    repairs to his home and commented on His clothes dryer dumping all that moisture into His garage. I will run it in the wall up to roof [ tar and gravel] I happen to have a 140 Gal. Kettle and a little 40 gal. for roof repairs.
    BINGO, HEY RICKEY BOY, BET YOU DON'T HAVE A KETTLE ! HA HA
    Re: Can I exhaust My dryer into hot water chimney ????
    i don't like the idea of the lint not making its way out, it is a bear to clean out the lint once it starts clogging the pipe.
      absolutely not. Besides clogging the flue or chimney with lint, you risk flue gas going right back through the dryer.
        tool. no kettle. but i do have a lead pot and burner.
        do you do shower pans too?
        dryer vents need to terminate outside and are limited to the manufacturer distance both total length and vertical height.
          I explaned he could die from carbon Monoxide ! All our eichler homes[slab on grade] Duct in wall to flat roof.
            I uploaded this picture and forgot to include it with my thread. This was a horizontal run, about 15' long, and dropped about 3' from the dryer duct location in the wall. This is from 3 years of buildup.
              I use a leaf blower ,with a towel wrapped around it to clean out My 8' vertical duct. of course this is at the wall bottom end. Roof looks like a snow storm hit!
                Hot water chimney? That the vent on the hot water heater?
                  Sorry,My mistake. He thought he could cut His 4" gas W.H. CHIMNEY PIPE and Y in the dryer. Only a college educated person would do this. I like being ENLISTED TRASH.
                    Ya, you "can" do it. As for fumes going up, then deciding to go down the dryer vent, I think it is pretty unlikely. My concern would be aside from that being straight wrong, condensation possibly forming in the 4 inch and dripping down and rusting out the tank faster. Or the 4 inch pipe depending on what it is made of.
                    and for carbon monoxide to actually "backfeed" through the dryer, I would think there would have to be some sort of draft flowing that way in the first place. Just seems highly unlikely to me. I have seen plenty of houses with no vent at all on the water heater, and the only complaint was from me. they never got sick or anything. I understand it "can" happen, but seems a little unlikely to me for it to happen if you have a properly vented tank.
                    But I would def say no to wye'ing anything into the water heater vent.
                    Again, just my thoughts on it.
                      CAN you? Yes.
                      You CAN also jump off a bridge, play on the freeway, etc. Should you? No. Would it meet code? No. Is it a good idea? No.
                        I can not believe this is even being discussed as a possibility on this PROFESSIONAL PLUMBERS FORUM!!!! UNBELIEVABLE!!
                          The manufacture has limits but it is the Code that specifies what the developed length (4' added for elbows) of the vent should be.
                            I WOULD NEVER ,EVER CONSIDER FOR A NANO SECOND, SUCH A DANGEROUS
                            HACK IDEA! I'm just sharing what homeowners have in their head. The IPC says 25ft max and deduct 2'6" for each 90. Yes I know We're U.P.C.. He gets to open wall,do cut out rock,clean up and rock.
                              Really!? No vent on the GAS water heater at all!? Yikes oh friday! That is scarey!
