40 years ago i did this
  • 40 years ago i did this
    I was building new homes on Cape Cod. When I was running My floor Joists in the bathrooms, this is what I did. Doubled up parallel joist on outside tube edge. Also framed all bathroom joists 12" On Center.Learned this from My older Cousin,Thanks Jeff. Only takes a little effort and a few joists. Bathrooms have a serious live load!
    BIG JIM in a cast iron tub , ON SAT. Nite with HIS DUCKEY.
    Re: 40 years ago i did this
    How did you know her name was Duckey?
      Because My Ducky calls Tool "Hot Tub Hubby "
        " How did you know her name was Duckey? "
        Now that is funny!.
          Also, what I do in all my rentals when it's time to replace a bathroom is frame up the walls around the tub 12" on centre...young tenants like to do "stuff" in the shower/tub, with their "friends".... the weigh of 2 people against a tiled wall can use an extra few studs!
            Before they find Your Hidden Cameras, can You post some of those DUCKLINGS?
              I hate it when the joists are 12" on center. Doubled up makes them equal to 10-1/2" oc. When hanging pipe in new construction you can't fit between them, so you have to flop around in the dirt or rat proofing. Ggggrrrrr!
                We had full basements,and My plumbers wern't Girley Men!
                  If it's T and M, I don't care how hard the work is. But, if bid, working for free because of unforeseen difficulties is the pits.
