Drip legs on some appliences,only ???????
  • Drip legs on some appliences,only ???????
    I put a 6" drip leg before ALL gas appliances. But, I often see them missing on some.
    Two examples are ,Gas stoves, and Gas logs. Why do You suppose they aren't ?
    Re: Drip legs on some appliences,only ???????
    I don't know about up there but we have really clean and dry gas. We have not been required to do drip legs in at least the last 40-years.
      Funny ,You said the same exact thing in 2005. We have to use them here. I enjoy reading old posts and visiting
      with "the dog" A plumber's plumber !
        the only thing i find in drip legs is oil and maybe a little metal from cutting threads
        never water
          are you sure mark
          at the last dinner get together, the gas sounded pretty wet and stinky
          i don't ever remember installing a drip leg. but have removed many from old school installs.
          same thing, occasionally cutting oil and thread shavings.
            City of Anaheim,Calif. requires a drip leg.
            wookie
              never water
              Thats why I call them dirt legs, most of the time. Around here, they want dirt (drip) legs on furnaces and water heaters, but rarely do I see them on stoves or dryers, can't explain it. But they don't want the drip legs exposed to freezing weather, even though I never seen condensation in one ever, & I installed many on roof top furnaces, & never got a violation, or had any problem with freezing. Didn't even think about it, until about 5 or 6yrs ago, when an inspector made me remove the drip leg on a nat gas backup generator. Reason why I probobly never thought about it,......BECAUSE I HAVE NEVER EVER SEEN WATER IN ONE.
                Well a lot of times manufacturers specs. requires therm on certain appliances.Got failed once for not having one on a furnace. Then was told we don't need to install them becuase the gas was cleaner and had less condensation . I still install them at the appliances.Not in the middle of a run where you have to drop down /jump up though. As far as the drip legs on generators etc. , most inspectors do not like them because they make it easy for you or someone else to add on after the fact..
                  in PA they want them and DE the drip leg had to be inside ,
                  i like when i see them on the run of a tee
                    2009 UPC Section 1211.8.1 For other than dry conditions, a drip shall be provided at any point in the line of pipe where condensate could collect. One of the towns I work in requires them. I think it's a pet peeve of the inspector (Authority Having Jurisdiction).
                      Drip legs are intended for unoccupied gas appliances. That would be any appliance such as a furnace, boiler, or water heater that is capable of turning on by itself. Stoves, dryers, gas logs, and fire places generally require someone present to monitor the start up.
                        We only are required at the furnace and water heater.
                          If I recall correctly, someone once posted that in his city a drip is required everytime a direction is changed...something crazy like that....maybe I'm wrong....Does anyone remember that post?
                            Yes that was Me on a S.F.
                            remodel. The inspector wanted it, He didn't get it. He's great for making up His own code.
                              Working in SF was the worst. You would have to have a valve and a cap to clean them out. By code they are supposed to be after the shutoff valve to the appliance. I think most inspectors there are not professionals, just appointed by a family member in city hall.
