Three inch pipe
  • Three inch pipe
    Okay guys got a call today on toilet rocking. I go and pull the toilet and find that they stubbed up three inch pipe and put styrofoam around it to keep the concrete off the pipe. They then installed the flange which goes on the outside of the pipe. Well it broke where the johnny bolts go so someone installed a spanner flange. Now the whole side where the spanner flange is broke off. How do you fix this?
    Re: Three inch pipe
    Try this:
    http://www.tallpaulsrentall.com/jackhammer.jpg
      Re: Three inch pipe
      Canplast makes a three inch internal flange with a long street neck that goes in the pipe about four inchs use your internal cutters cut out the old flange chip the styrofoam out and fill it with sure crete put in street flange might work... I hate using them but with broken three inch flange not alot of options
        Re: Three inch pipe
        are we assuming it's abs/ pvc pipe and you need to remove the flange without damaging the pipe?
        there is actually a hole saw type of bit out now that cuts the fitting off and leaves the pipe fine.
        also a little heat from a heat gun and you can chisel off the flange after cutting at least 3 score marks vertical with a sawzall from the outside towards the pipe.
        cast iron is much easier as lead is easy to pull out from a joint.
          Re: Three inch pipe
          Sorry yes it is pvc. Havent seen the new bit that is out that may be worth its weight in copper.
          Seanny thanks I did know those did exist just hate to use them just really trying to figure out what everyone else does and why they dont make a code prohibiting three inch on water closets.
            Re: Three inch pipe
            Rick, You know who makes the hole saw for this ???Sounds like another must have for the collection
              Re: Three inch pipe
              3" is legal here for toilets.Why do You feel It's a problem?
                Re: Three inch pipe
                  Re: Three inch pipe
                  off the top of my head no
                  i can't remember the company. for some reason a pirannia comes to mind.
                  a real nasty looking holesaw.
                    Re: Three inch pipe
                    i guess my guess was a good guess
                    Pipe Parana | Step-By-Step Instructions For Use
                      Re: Three inch pipe
                      Because when it breaks and with plastic flanges it will break it is almost impossible to fix right.
                      Its legal here as well but there is always a gap in the concrete that tapers so you cant get a saw blade in there to mike slits to get it off and never seems to be anchored to the floor due to the lack of concrete. I say spend a couple dollars more and use a 4x3 1/4 bend and stub up 4inch and let them pour concrete up to the pipe and install flange inside of pipe for easier fix later.
                        Re: Three inch pipe
                        This tool seems really nice but would love to see one in real world use not strapped to a vise in a shop. Wondering if anyone out there in the forum has ever seen them or used them?
                          Re: Three inch pipe
                          The real problem was the original plumber's attitude. I would never walk away leaving leaving something that hacked. I'm sure all His other work is the same quality!
                            Re: Three inch pipe
                            yes. They are OK, kind of pricey for the set when compared to wheeler-rex internal cutters. Easier to dull bit than with internal. Watch our for concrete, gravel,etc.
                              Re: Three inch pipe
                              Obviously , The 3 or 4" Riser isn;t meant to structurally support the throne . Those ROUND holes on the flange go into concrete,pour rock or wood.If it ain't there,put it there. I Know the original plumber , His name is " VAN CRAPPER "
