ID these please...
  • ID these please...
    Seems generic, maybe a Danz or some other big box valve. To pull the cart, I'm going to have to break some tile. The Customer would rather not purchase a complete valve set. What is it?
    Not sure which replacement cart for this PP valve. I think it's the P974-491.
    If you could help me out, it would be appreciated.
    Re: ID these please...
    Concinnity?
      You're on the money with the PP part no.
      Here's the entire cut sheet in case you need other parts.
      As for the first one, it looks like a Grohe although I couldn't find any info.
      Is there a separate on/off valve? If so, post pic.
        Although not a necessarily a newport brass valve, the cart was a newport brass 511. Fit perfectly and w/ a little mod on the spline worked great. Thanks for all the help!!
        http://www.plumbingpartsdepot.com/newportcart.pdf
