Pool Inspection Images
  • Pool Inspection Images
    Its been a while since I posted images that pool technicians have sent into me. May be interesting to some of you. The Las Vegas pool show is next week so I am pulling together some images and video to be able to show people at the show.
Name:	Pipe cut durring install.jpg
ID:	635045Click image for larger version
Name:	Rusted Butterfly Valve.jpg
ID:	635046Click image for larger version
Name:	Unglued Joint.jpg
ID:	635047Click image for larger version
Name:	Foam Peanuts Jammed in Pipe.jpg
ID:	635048Click image for larger version
Name:	Hairline Cracks.jpg
ID:	635049Click image for larger version
Name:	Insect Hole In upper Left.jpg
ID:	635050Click image for larger version
Name:	Chemically Damaged PVC Wall.jpg
    Re: Pool Inspection Images
    A few more..Click image for larger version
Name:	Porely Installed Joint.jpg
ID:	626466Click image for larger version
Name:	Old Style Flex PVC Rotting.jpg
ID:	626467Click image for larger version
Name:	Nail Hole In Top of Pipe.JPG
      looks like the soft pvc flex has got the worst of it.
      now if you really want to make an impression at the vegas show, bring out the calendar girls in outfits
      at the end of the show, break out the ridgid speedo
      guarantee you'll have a busy booth.
      i'll run it by fred
      i'll clear my calendar
        in the 2nd set of pictures first picture is that just extra glue on the left side and the cut was not a good one
        and what is that in the 4th picture
          Flex pvc looks like a hole was drilled through it....multiple times.
            Somebody didnt debur and they didnt seat it all the way into the fitting
            Pic #4 is packing peanuts that someone let past the skimmer.
              calendar is all cleared
              i might just have to take a dip in the pool, show
              now if i can only dig up my red speedo
                Boy oh boy, those are some damning pics for proving a point. That is a nifty tool to have for sure.
