3 phase water heater
  • 3 phase water heater
    went out to trouble shoot a 3 phase water heater tonight at a new theater we plumbed. It's a 460v water heater with a blown element, been on for a week now. When I tested incoming power I found 277v on each leg. To me that equals out to 831v, Now, I don't know a Damned thing about 3 phase, so does that sound right at all? Trying to contact the manufacturer met with a dead end, even their sales reps told me it would just have to wait for Monday before I could order the element.
    Re: 3 phase water heater
    I`d contact an a electrian to cover your back
    Tony
      You have 277 volts between any of the three legs to ground. If you put a meter between any two legs you will get 480 volts.
        OK, that makes a bit more sense killavolt, thank you. when you test between the legs, do you actually touch both leads of the meter to their respective hot wires with the meter set to AC? "now I'm just curious, Not going to try it.....this time"
          Do you own a dollar store meter, or a proper one?
            I use a fluke 116
              Yes.
                You need to be careful with all electricity but when you get into the larger voltages serious injury comes much easier. 120 to 277 is like a baby slap to a punch in the nose.
                  Mojo: It sounds as though you shouldn't be in there. I was collecting a vibration data on a pump in an engine room aboard ship about 20 years ago and my arm accidently brushed against something that was energized with 480v 3 phase. My arm was pretty much dead for about an hour. Nothing like 120v.
                    No doubt geno. I Shouldnt be in there
                      I was in the Navy with a guy that did the same thing, but he lost his arm. Lucky he didn't die.
