Weird CPVC ?
  • Weird CPVC ?
    Ok here's the skinny I have a CPVC sample ( have not been on the job site yet)
    The wall thickness is ok But this stuff measures .681 too big for 1/2 too small for 3/4
    What is it and anyone have some transition fittings ?
    Thanxx in Advance
    Re: Weird CPVC ?
    CPVC has its own fittings and those fittings will allow transitions to MIP or FIP fittings. It is off size to PVC and is not the same pipe.
      Re: Weird CPVC ?
      I have standard cpvc it is not the same size
        Re: Weird CPVC ?
        It would be better for everyone that touches that job to get real CPVC
          Re: Weird CPVC ?
          Thanxx in Advance
          No manufacturer's stamp on it ?
          Years back the Genova company produced some very odd size pvc pipe so it may be theirs though I can't recall if they did cpvc or not
            Re: Weird CPVC ?
            Normal Cpvc on left Weird size on right both sitting on a dime ...
              Re: Weird CPVC ?
              It almost looks as a little sanding on the exterior of the normal and a little round file on the wierd and the 2 should glue together without a fitting. That's crazy.
                Re: Weird CPVC ?
                Are you sure those dimes are the same size? Just kiddin. But looks way too different to sand down. Man the things we run into.
                  Re: Weird CPVC ?
                  I think the one on the right is pvc not cpvc
                    Re: Weird CPVC ?
                    Nope 1/2" pvc on the left ...
                      Re: Weird CPVC ?
                      My answer for the shell game is "the middle one"
                        Re: Weird CPVC ?
                        I think NHMaster is correct that the one on the right is PVC pipe.
                        I unfortunately run into 1/2" PVC fittings glued onto 3/4" CPVC pipe fairly often out here. I know it's an oddball size, but a quick google search says there are companies that make 3/8" PVC pipe. That would be about the correct size for the pipe in your picture.
                          Re: Weird CPVC ?
                          Makes sense to me Thank you ! anybody have some 3/8 pvc x 1/2 Mpt adapters ?
                            Re: Weird CPVC ?
                            removed this pipe replaced it with PEX ...
                            Anyone want samples PM me your address
