LEARNED SOMETHING...WANT TO SHARE
  • LEARNED SOMETHING...WANT TO SHARE
    a little knowledge that was passed on to me...thought i would share here
    learned something the other day from an old timer plumber tht i thought i would pass on, many of you might already be aware of this...but i will post anyway. i had that seeping problem on my sewage stack, plumber came out and repacked the lead. then told me "if it continues to seep you dont need to call me, do this yourself" anyway it is a vertical joint with cast iron pipe, requiring a lead joint. lead being very hard to work with vertically. he showed me a product by quickrete he uses in lieu of lead called "hydraulic water stop, instaplug cement". available for about 4 bucks a tub, it dries quick...easier to work with, and makes a great seal. will probably last longer than led too. actually needed to use this today on another problem, and it worked well. and cut the job in half for time. just something ithought i would pass on
    ed
