206 soilpipe cutter
  • 206 soilpipe cutter
    Hello all, I recently purchased a 206 soilpipe cutter off of ebay. Of course the listing said it was in working order but when I got it the knob just spins and doesn't open or close the cutter. I took it apart and found that the steel pin was sheared off under the knob. Ok, a roll pin will fix that. Looking at the parts breakdown from Ridgid it shows a drive blade also in the assembly, which is missing in mine, so i ordered one. Has anyone worked on these before? From the picture I can't figure out how the blade goes in, what it's function is, and how it interacts with that steel pin that sheared off. Any ideas? Thanks
    Re: 206 soilpipe cutter
    are you referring to part number 22
    http://www.ridgid.com/CatalogDocs/206.pdf
      Sounds like the last guy jammed the jaws and applied a 2' pipe wrench to the knob to release it. Very common problem with the 206 so be careful to have the jaws fully open and the chain as tight as possible before you ratchet it closed.. or it will jam on you too.
        See the attached pictures. The drive blade is the "S" shaped piece. It gets pressed into the "ratchet shaft assembly" (part 23). The knob (part 9) has a forked end that engages the drive blade. The purpose of the drive blade is to allow the knob to slip if it is overtightened instead of breaking some internal parts.
ID:	15808Click image for larger version
ID:	15810Click image for larger version
