Cheap Chinese black iron pipe
  • Cheap Chinese black iron pipe
    Running a few hundred feet of 2" screw pipe and can't believe how poor the chinese pipe and fittings are. A coupling, no, every coupling wobbles when you hand tighten it. Had difficulties getting the die on some of the pipe pieces (some seemed bigger than other pipe). I use a power pony.
    I prefer jobs where American pipe is specced.
    David
    Re: Cheap Chinese black iron pipe
    Just because it is not specified does not mean you have to support chi-com markets.
      Correct, but that's all the supply house had in stock.
      David
        shoot, I've seen bowed 2" C.I. pipe from AB&I made right here in the USA. I'm also a fan of letting supply houses know I won't buy from them if they carry sub par material. Gotta check everything before installing it nowadays
          David
          only 1 of the 4 supply house i go to stocks domestic threaded fittings. of course it's 2 to 3 times more money. yet they don't stock the threaded domestic pipe.
          they all stock domestic n.h., copper, plastic pipe and fittings.
            David
            I needed Sched. 80 stuff and I was told it was a special order at one of the largest supply houses in New England, WTF.
              The fittings are the worst!
