Silver soldering saw blade carbides
  • Silver soldering saw blade carbides
    Have oxy aceteline tanks, And B tanks. I will make a small steel revolving table to
    silver solder carbide tips on in the field for My friends Lucas Mill. I need 1100 degrees.
    I think the b tank is only good for 800 F ,Am I wrong? Mon I receive My metal detector. Friend doesn't have one,Lost 3 blades on My trees! Only 5 tips per blade.
    Thanks Tool
    Re: Silver soldering saw blade carbides
    Well tool ,The Pratical Machinist site says go Oxy Acceteline on Hi Temp Brazing.
      Thanks Kevin,You're always there for Me,
        Did I just hear a whine off in the distance?
        ------- Henry Ford
          acy/ b tank will easily heat up that blade pretty quick due to the fact the blade is a thin and a small area. how about the temper change after brazing?
          oxy/ acy will be faster, but on such a small area, i think you might need more of a jewelers torch setup.
            TOOL, would like a lil cheeze with that wine ?
              great tutural 2 Masters google U Tube brazing carbide tips part 1 of 2
              carbide processors . Heat is on the tips, saw mill blades are thick
              Last edited by toolaholic; 01-03-2012, 07:08 PM. Reason: PLEASE HELP WITH THE URL IF U CAN
                here you go tool
                didn't see anything for bandsaw blades, but here is the one you were looking for.
                  here you go tool
                  Thanks Rick, lucas Mill has a circular blade. I got 2 big redwoods,Next week I get a 40' doug fir 40 plus inches at the butt
                    OK so you get the new teeth brazed back on the blade, (how you going to sharpen them), the machine for sharpening carbide teeth is not cheap, I use to do all my own steel blades and then they were coming out with carbide teeth and said no way on spending that kind of money for a proper tooth sharpener machine, on a carbide tooth you form the shape the face and the sides of the tooth to its desired shape, after brazing on a new tooth,
                    unlike on a old steel blade you either hit the face or the back of it to form the tooth after setting it correctly, (which you still do if your just touching it up).
                      This is My friends Lucas Saw Mill. He has the sharpening grinder set up. When You hit a nail with 27 H.P.. You need new teeth!
                        i would think that the teeth are already sharpened and pretinned.
                        couldn't you get by with a die grinder or dremel and diamond wheel.
                          you may want to see if there are other grades of carbie teeth that may take the nails better, (I know they make a lot of carbide steel cutting blades and tools), but not up on all the grades and the applications for each.
