Jason jetted bath tubs
  • Jason jetted bath tubs
    Been Years since I installed one of these. I believe they require a dedicated GFCI at the service panel. Right?
    Re: Jason jetted bath tubs
    You need (2) 20-amp dedicated GFI protected circuits. (1) for the motor & (1) for the heater. What I do is run my wires from the panel box to (2) 20-amp blank GFI's that are out of the way in the bathroom. Then run my wires to (1) 20-amp outlet (break off the centers) behind the tub. That way if the GFI trips you don't have to remove the access panel to the tub or go to the panel box to reset the GFI.
