Flooded bath, tub overflow drain couldn't keep up
  • Flooded bath, tub overflow drain couldn't keep up
    Going to look at repair work for the unit below , appt. building. I said" maybe I should check the tub drainage ." She said it drains ok. Can an unfouled drain n overflow
    always keep up with the water ,stopper in place ?
    Re: Flooded bath, tub overflow drain couldn't keep up
    I guess that would depend on the Tub flow
    i would have to test it to know
    The over flow itself could leak when tested
    and you always have to rule out the children
      the overflow was never designed for full force. just more for water displacement when entering the tub. same goes with bathroom sinks and most toilet tanks.
        Well she has 2 problems. The fiberglass shower pan has a gasket leak on drain. In bath #2. Supply house sell gaskets alone? Bath tub was left unattended while filling. Serve pro took care of most of that. Thanks Tool
