"Real" Plumbing Lead Closet bend ...
  • "Real" Plumbing Lead Closet bend ...
    This was installed before I was born ... will be there after I'm gone ... real craftsmanship ...
    Read pride NO building codes ! ...
    Re: "Real" Plumbing Lead Closet bend ...
    That was code in St. Paul, Mn. for many years!
      I found one the other day in the crawl space of an older home. it had been removed and left years ago when the owner re-did the drainage with plastic. there's a home a few blocks from me that has an old laundry tub downstairs with a 2" lead bend / drum trap to the stack. fascinating...
      That logo is interesting to me because I didn't know lead bends were actually manufactured and sold. I thought they were hand made on site?
      Can anyone out there chime in more on lead bends? were they bought in specific lengths then cut to size according to the rough in?
      Also, why do you sometimes see lead used and not cast iron?
        Way before my time
        I'm sure it was a factory piece !!
          We have a ton of lead bends here in our area. It's the only time I'll use a horned wax ring when resetting a toilet.
            On average I remove a few failed lead bends a year in the twin cities. I imagine they were sold in standard lengths then cut to size and the joints wiped in place. I also presume they were used because they were cheaper to buy and install than cast 90's. The lead could be somewhat shaped to fit the space the bend was in unlike cast. With the lead bend there's almost never a flange, they peen the lead over the floor and set the toilet. So there's one wiped joint / caulk joint instead of two or three caulk joints.
            What's cool about the picture is I've never seen a manufacturers tag on any lead bend, lead pipe, or lead drum trap.
              Funny, My H.D. carries them, Next to the cast iron radiators.
                If I pull a toilet and find one I install a brass flange beat the lead back down and reset with a horned wax ring. I almost never replace them. I also like the drum traps the old timers used above a living space. It has the plug on top. The plugs come right off like pie. They stay clean and the plug is usually flush with the floor.
                AllurePlumbing.com
                • leak detection
                • drain cleaning
                • utility locating
                • conductor fault locating
                • and other specialties.
                  When i did plumbing on Long Island 26years ago i do remember getting them from a supply house
                  to tale the masters test back them you had to take a brass ring and put it on the lead tube by wiping the lead joint
                    Agreed, the only place for a horned wax ring.
                    David
