leak detection
  • leak detection
    A.L.D. can't compete with me on those hard locates. They use helium....thanks Obama, the first thing that has helped me.
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
    Re: leak detection
    I'm a temperature mapper on the hard ones (Infrared thermography ).
    Most leaks that are large enough to show through a slab I can normally track by sound (stethoscope).
      Re: leak detection
      I also use thermography. The last time I was going behind another they had missed it in a big way partially due to the water getting above the vapor barrier and giving a false locate. It is awesome for radiant and snow melt systems.
      AllurePlumbing.com
      • leak detection
      • drain cleaning
      • utility locating
        Re: leak detection
        Obuma is Special
          Re: leak detection
          I don't get it. Is ald a government contractor or something?
            Re: leak detection
            Sorry, american leak det.
            AllurePlumbing.com
            • leak detection
            • drain cleaning
            • utility locating
