Smoker
  • Smoker
    Smoke Testing
    Has anyone built this and did it work out for you?
    Re: Smoker
    Reverse the hose on a shop vac and you got the same thing. Best to use a small weak shop vac. Too much air and the smoke get too diluted to be visible.
      Re: Smoker
      An electric leaf blower on low speed with a fernco coupling at the end and hold the smoke bomb with a made to fit coat hanger. Call the fire departments first.
      AllurePlumbing.com
      • leak detection
      • drain cleaning
      • utility locating
      • conductor fault locating
      • and other specialties.
        Re: Smoker
        I've done asimilar thing with a tee and dryer duct and leafblower. It is too strong and will blow toilets. It has to be held back from the tee a few inches to not be too strong. I think the fart fan is a better concept. The smokies work well and don't stink too much.
          Re: Smoker
          Yes, a few inches away and you are ok. I also put the bomb in between the vent and the blower.
          AllurePlumbing.com
          • leak detection
          • drain cleaning
          • utility locating
