Sprinkler valves
  • Sprinkler valves
    Is there a good place to get some handles? Someone stole some. I do not know the brand yet.
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
    Re: Sprinkler valves
    you can try T and S brand of handles.
    How to find the Best Australia Plumbing Services?
      Lol, you're funny. I found out they were not the wheel handles. FD connection st two places and caps on the fire hydrant. I called the city to find out what type of threads that was required for the connections. The hose connections need to be done by a licensed fire sprinkler contractor. Fire hydrant, nobody cares. The funny thing is the city could not tell me what type of thread that was required. I will bow out gracefully and let the other contractor take over.
      AllurePlumbing.com
      • leak detection
      • drain cleaning
      • utility locating
        Personally, I would have called a local water works supplier and asked them what threads were required in that particular city.
          I called and they had it for two major cities but only knew because they were buying from them, not that they had a clue as to the particulars of that city or any others.
          AllurePlumbing.com
          • leak detection
          • drain cleaning
          • utility locating
            Try these guys they have all kinds of old oddball stuff.
            Ti-SALES inc, Water works supply Neptune water meters Ford brass and pipe products LMI Pumps American AVK hydrants and valves Smith Blair clamps and couplings and a whole lot more!
              If it's in Raleigh, they have their own, proprietary hose thread for FDC's and hose valves. I believe hydrants also. 98% of the rest of the country is on NST 2.5" hose threads.
                It seems that every city has one or the other and the hydrants must follow suit as well. I was amazed that every city in the country didn't have the exact same connector threads. Thomasville is NST threads 2.5" and the hydrant was 4.5 & 2.5 & 2.5
                AllurePlumbing.com
                • leak detection
                • drain cleaning
                • utility locating
