Corrugated plastic pipe to pvc?
  • Corrugated plastic pipe to pvc?
    Is there an actual connector or adapter available that will connect 4" black corrugated plastic drain pipe to 4" pvc? Or am I putting to much thought into this?
    Re: Corrugated plastic pipe to pvc?
    I have yet to find one....sorry
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
      Duct tape?
        Corrugated Pipe and Downspout Connectors | Fernco Connectors, LTD | Canada
        http://www.fernco.com/files/installa...es_install.pdf
          Now now...we need to keep those supply branch ducts at least 12" away from any end cap.
            I think you have to use cork for joining these two pipes. It is better to ask plumbing expert so that you will get solution in a shorter period of time.
            Heating And Plumbing Supplies
              Yep, cork. that's the way to go for sure Doohhhhhh
                We do drainage. corrugated [ elephant trunk ] is garbage , and outlawed for underground here. It collapses. SDR 35 is a good choice. You'll never see a geo tech put this crap on plans. CORKETY CORK CORK !
