mixing abs and pvc
  • mixing abs and pvc
    I've always felt this was a recipe for problems. Stopped in to check out our new Lowes (first big box in this area), and lowe and behold what's on the shelf but Oatey "transition" cement for gluing abs to pvc and verse visa. wtf?
    Who knowes about this? Is it legal? Does it work? Would you ever do it?
    Re: mixing abs and pvc
    as far as i know, the old transition glue was for non pressure applications and was more of a contact cement than a welded joint. the 2 plastics are different.
    truthfully, i would use a no hub/ mission band for a transition fitting and not worry about the glue.
      We use transition glue in Toronto for gluing 4" ABS (ABS is used extensively in homes here, not PVC) to 4" PVC sewers under the concrete floor in the basement going out to the city sewer.
        Can I ask a really stupid question:- What is the idea of using ABS as opposed to PVC. Ove rhere we dont see a lot of ABS. When we do it is gererally George Fischer and god damned expensive. Mind you great product to work with and GF have been doing it for a long time as well.
          Code here allows 1 joint ...It Can't look like a "Zebra"
            Honestly I don't know. The stuff is way more expensive (especially lately), needs supported more as it sags more, and you can't see as well in it with a camera. I don't much like it but if that is what is there and I've got to cut in a cleanout or whatever, then that's what I'm using.
              Transition cement is not an approved method here.
              Use a no hub band, it is much better and will last forever.
              Plumber Raleigh,Plumber Cary,Plumber Apex ,Plumber Apex, Plumber Morrisville,Plumber Durham, ,Plumber Holly Springs,Plumber Chapel Hill,Sump Pump Raleigh
                ABS pipe laying out in the Phoenix sun, (115 here today) will look like a dog's hind leg after 15 minutes. Great stuff when the ditch is a little out of line.
                  Multipurpose glue for PVC/ABS transition is illegal here as well, as the code calls for a mission coupling. However, we rarely see ABS and if I do, any alterations always seem to be done with glue instead of the mission coupling.
                    So Arizona am I reading it right that you guys would run 100mm abs underground as well
                      I remember back in the 80's when we were running ABS pipe and had it delivered to a job site on hot days. It was my job to flip the pipe on the ground because the sun would bend the 20' sticks into a "C".
                        Also known as long sweep 22, s...
                          transition cement not allowed here as well, no-hub adapters with a no-hub coupling, or threaded adapters are used.
                            No. We'd run 4" ABS underground. Miles and miles of it.
                            BTW. Sorry for the delay in responding. Been really busy.
