Hercules MegaBubble leak detector
  • Hercules MegaBubble leak detector
    Have no idea how it works on actual gas leaks, but this stuff found 3 air leaks in tires that defied detection with homemade soapy water. One had been making me crazy as it took about two weeks to leak down. Thumbs up; the stuff works.
    Re: Hercules MegaBubble leak detector
    try windex next time with no ammonia as it will eat stainless steel on flexes.
      Been using megabubble for years.Got tired of not being able to find microleaks.
        I use them and Big Blue. Both work well. Most all of these types of leak detectors are corrosive and need to wiped dry, rinsed somehow, and then dried again. I don't think Snoop will rust black iron. For tires, a bathtub with Dawn unless you have a wife like mine. If so, I think the auto store usually carries Wagners* spray cleaners. I think its a bleach white. Anyway, 50/50 with water does the trick.
        AllurePlumbing.com
        • leak detection
        • drain cleaning
        • utility locating
        • conductor fault locating
        • and other specialties.
          Snoop works. Also safe for stainless steel. Use it all the time on 304 and 316 SS instrument tubing and on copper tubing.
