Roots in sewage ejector pit!!!
  • Roots in sewage ejector pit!!!
    I came across a sewage ejector pit, where roots are growing into the pit around the incoming 4" abs pipe. I have tried methods such as silicone and concrete, and have used crystals trying to kill the roots. However, they manage to keep growing in. Any ideas????
    Thanks!
    Re: Roots in sewage ejector pit!!!
    Remove the miscreant, ie., the tree causing the problem.
      it's not to uncommon for roots to get into the pit.
      is it a real sewage pit or an area drain/ emergency drain pit and pump like in a subterraneum garage i see in la. is it a fiberglass basin or concrete?
      if you pump out the water to the lowest level and add 2# of root-x, let it sit for 4 hours or more before the water level rises, this should kill the exposed roots for a year or 2.
