Will I survive?
  • Will I survive?
    Imagine being trapped in a building on fire that you cant escape only wait.
    Will I Survive?
    As plumbers we breath like this all the time right:-)
    Re: Will I survive?
    Think I'll just go for a different trap and hope the methane is down.
    Most plumbers won't die in a building fire. I know I'm gonna' create a sprinkler system in the building real fast when necessary.
      Re: Will I survive?
      note the non-flushable wipe stuck on the horn...
        Re: Will I survive?
        Great picture and yes you will survive.
        Water Line Repair Services
          Re: Will I survive?
          True, and you're loved ones can still have an open casket funeral when you die from smoke inhalation.
            Re: Will I survive?
            No way. I'll be sucking methane and blowing fire like Gene Simmons. Gonna' look like Spot on the Munsters coming out of there.
              Re: Will I survive?
              while you're sucking wind in stall #1
              your coworkers are blowing wind in stall #2
              talk about buddy breathing.
              you'd be better off going into the break room and finding the whip cream can
                Re: Will I survive?
                If he inhales and exhales in that tube he will not last long. He will be inhaling and exhaling the same air. The only way that would work is if he inhaled from the tube and exhaled out of the tube.
                When seconds count, the police are only minutes away.
                  Re: Will I survive?
                  Might as well put the tube up Your BUTT !
                    Re: Will I survive?
                    So is that you offering to insert the tube in your own butt Or are you offering to insert the tube in someone else s butt... Tool, we are all Men here (so far) so that line was a little weird.. Of course if that is the way you roll do your thing...
                      Re: Will I survive?
                      What's next bill " Diving in septic to survive Lava FLOW ?????? " Funny Man
                        Re: Will I survive?
                        I never worked any were with out a window
                          Re: Will I survive?
                          Please Please someone post these signs around an engineers building, then pull the fire alarm and you tube what happens next. Probably like this guy I worked for.
                          Plumbingbyjay (redneck compactor) - YouTube
                          "don't put that in your mouth, you don't know where it's been"
