Diy using 1/2" drill running 7/8" sectional cable Page Title Module
  • Diy using 1/2" drill running 7/8" sectional cable
    Where i work selling cables and cutters,
    i have been getting calls lately from diy home owners who have had a plumber
    out to snake their main sewer using the "plumber rick" special a 1/2" drill
    running sectional cable now they want to know if they can buy the same setup
    and do their own drains with out any experience ?
    What do you professionals thank about this ?
    Give me some feed back i have over 35 years experience running all kinds of drum
    machines and yet i would thank twice about using this way !
    JERRYMAC
    E-MAILJERRYMAC777@GMAIL.COM
    FIRE SPRINKLER CONTRACTOR,
    SINCE JAN. 1989
    Re: Diy using 1/2" drill running 7/8" sectional cable
    I don't think you or Trojan could afford the associated lawsuits.
      here's the issue. it's not safe
      even plumber rick doesn't use the 7/8'' x 15' sectional with the drill/ timberwolf.
      the 7/8'' is not the issue. it's the 15' of flopping cable with no choice of shorter sections when you hit the roots. you'll turn the 7/8'' into a pretzel if you're lucky or a choke collar if you're not
      not to mention the ones that do use the drill setup, have years of experience and feel for this kind of work.
      eventually when ridgid comes up with a 7/8'' x 10' or a 7.5' and a 4' section along with some innercore to match, then i'll man up and use the drill. just don't hold your breath that will be anytime soon.
      hopefully, i'm not named in the pending lawsuit when people don't listen to advise.
        Rick is correct. I saw a plumber using this technique once and the blowback from the cable was awesome. He hit something with several feet of cable exposed and it went flying. I'll stick to my drum machine....................
        David
          I run both 1.25" or 7/8" Electric Eel cable with my drill. It's not as dangerous as it sounds, but I have the experience to know what I'm doing, the homeowner doesn't and I could see it heading south for them real quick if they don't pay attention to what there doing.
          Will Rogers Plumbing
          Moore, Oklahoma
          405) 323-2852
          www.willrogersplumbing.com
            Ever use sections in a Drum ?
              Yes I run 75' of 5/8" Electric Eel sectional in my Electric Eel Model N.
              Moore, Oklahoma
              405) 323-2852
                What's wrong with running the Eel J cable ?
                  6' sections would be a nice choice for indoor work. easy to control and keep off the ground.
                  what's the going price per section?
                    I haven't bought a section of J-Cable in probably over a year. Maybe $30-$35 per section.
                    Moore, Oklahoma
                    405) 323-2852
