Mechanical Tees
  • Mechanical Tees
    I'm currently working on a chilled water system and also a heat reclaim system that are piped with sch40 plastic. I've been told there are mechanical tees that are approved for use on sch40, but I'm not able to come up with any info.
    Anyone here have any ideas?
    Thanks.
    Re: Mechanical Tees
    The only thing I can think of is Flanged. How big of Pipe? I am guessing this for the Water towers? You would have to glue the flanges onto the tee and then use bolts and gaskets. I would be afraid of any other method.
    "don't put that in your mouth, you don't know where it's been"
      Re: Mechanical Tees
      they probably mean something like this:
      EBAA Iron, Inc. - AWWA PVC Pipe Restraint and Joint Restraints
        Re: Mechanical Tees
        Or, Ford Meter Box - Product View
          Re: Mechanical Tees
          Thanks for the input so far. What I'm really looking for is something like the Victaulic 920. Something that I can drill a hole in the pipe and then bolt on a brached outlet. What I'm running into is having to install tees with bushings, male adapters, then a threaded coupling to install sensor wells and thermometers.
          I'm working with 6", 3", and 2 1/2" primarily. Chiller sits on the roof of a 4 story building and feeds 2 AHU's on the main floor.
          I've been told Spears makessuch a device, but I'm having trouble accessing them online to find out.
            Re: Mechanical Tees
            u-bolt mechanical tee suppliers and u-bolt mechanical tee manufacturers info - at SeekPart.com
            mostly china
            Spears Manufacturing, PVC & CPVC Plastic Pipe Fittings & Valves (this works for me)
              Re: Mechanical Tees
              Anvil Piping Product - Grooved - Gruvlok® - Branch Outlets - 7045 Clamp-T, FPT Branch
              Is this what you are looking for??
              Not sure if it would work on plastic pipe, have used thousands of them on steel pipe.
                Re: Mechanical Tees
                click on the drop down menu to the left, under grooved products for more of the same only different saddles.
                  Re: Mechanical Tees
                  Yep, ideally that's what I'd like to use....... I,too, have use a bunch on steel. They sure would be handy if I had something that was approved for plastic.
                    Re: Mechanical Tees
                    My guess is you're not going to find anything.
                      Re: Mechanical Tees
                      Found this in about 15 seconds searching. Can't be what you need can it?
                      http://www.spearsmfg.com/new_prod_an...2_0912_web.pdf
                        Re: Mechanical Tees
                        Hhhmmm........ that looks interesting. Not quite what I was picturing, but may be the ticket.
