Gerber Viper
  • Gerber Viper
    Just installed my first Gerber Viper today and was pretty impressed. I like the large water spot compared to the American Standard Cadet 3 I usually use. Anyone else here use the Viper?
    26+6=1
    Re: Gerber Viper
    We have been using Gerber for easily 20+ years now, and its still a fantastic toilet.
      Re: Gerber Viper
      All my toilets are Vipers. Good, solid toities.
        Re: Gerber Viper
        my supply house just started to stock the gerbers and i'm waiting for the units to get fully stocked at the local level.
        should replace my toto drakes with the viper and save some good money. plus the viper ballcock has to be better than a toto/ hunter pos ballcock.
          Re: Gerber Viper
          Damn fine toilet.
          AllurePlumbing.com
          • leak detection
          • drain cleaning
          • utility locating
          • conductor fault locating
          • and other specialties.
            Re: Gerber Viper
            Gerber is the only toilet I sell unless someone wants something else specifically. The Viper is my "go to" toilet but I also like the upgraded Avalanche. I have the Avalanche in my house and it's great. Uses the larger flapper etc. I've never been let down by Gerber, no call backs, no defects etc. They're just great toilets.
              Re: Gerber Viper
              I have problems with the trip levers moving on them. They don't come tight from the factory and when you snug them up they tend to break. I wouldn't care but the chains tend to have a pretty specific length at which they'll trip the flapper with just a quick punch. The 10" rough in tanks are barely functional as far as the flapper and factory trip lever are concerned . Also the plastic wing nut connectors for the tank to bowl are nonsense, you end up using a linesman pliers to snug them up. other than function and installation they seem fine. But they're cheap so guess what i get to put in.
                Re: Gerber Viper
                I usually buy the tank to bowl kits with three bolts from WB. Almost any toilet I install gets them sealed out.
                AllurePlumbing.com
                • leak detection
                • drain cleaning
                • utility locating
                  Re: Gerber Viper
                  I take it you're talking about Gerber? I've never had a problem with what you're talking about. The trip levers have always been very tight and have never had to adjust them.
                    Re: Gerber Viper
                    If i don't snug them down I end up with call backs because the trip lever assembly rotates and holds the flapper up just a hair and the w.c. runs
                      Re: Gerber Viper
                      Don't think I have ever ran into this problem either. Do you think it may have been a bad batch?
                        Re: Gerber Viper
                        Just put an ADA Viper in today. I like the way the bowl is cast where you need to get a wrench on the tank bolts. Its flat just in the back so you can actually get a wrench on the nut and you can see the nut without having to lay on the floor. Ive had to use a socket on some. This all started because I could not get a Cadet 3 in 14" rough on Monday and had no other options but the Gerber. Large water spot, flushes well and a decent price point. I think Gerber has a new customer.
                        26+6=1
                          Re: Gerber Viper
                          Yes they are very easy to install. Very plumber friendly.
                            Re: Gerber Viper
                            I agree that the plastic tank to bowl nuts on the Gerber are crap. You have to use pliers on them to get them tight. The tank to bowl system on the Kohler Cimarron is pretty awesome by comparison
                            The only other thing about Gerber that I do not like is the MADE IN CHINA stamp on the box.
                            Rick, the viper ballcock is Fluidmaster. the flapper is a coast clear vinyl with the plastic float insert. Both can be replaced with generic stock parts. No special ballcocks or flappers needed.
                            BTW, I have installed about a dozen Vipers in the last year and have not had one call back for a leak, running toilet, broken trip lever, etc. Also not a single has been clogged yet. Customers also impressed with the bowl wash (1.6 GPF, I have not put a 1.28 GPF in yet).
                              Re: Gerber Viper
                              Its a great toilet and its the only one I will furnish and install....but what out there doesn't say made in china? LOL!
                              Derek
