Commercial sinks n floor sinks
  • Commercial sinks n floor sinks
    With in 5 ft. ,no trap on sink. Our code requires a trap on sink to floor sink. Can You give Me the Logic? Of course floor sink is trapped. Thanks Tool
    Re: Commercial sinks n floor sinks
    I assume by floor sink you are saying floor drain? Are you saying the sink dumps into the floor drain which is trapped ? Is there an air gap between the sink drain and the floor drain?
    Derek
      Yes trapped 12"x12" floor sink 1" air gap on Big S.Steel Comm. sink. Thanks
        Kevin
        Good question. Is there a reason for it, like maybe your buddy Dan is out to get you? CPC 803.0 states that any any direct waste line more than 5' and less than 15' will require a trap but not a vent. Why? Because it says so. Furthermore, it says if you do run a vent, it can't connect to any other fixture's vent. Thanks for the idea. I'm going to bring the whole indirect waste section (chapter 8) up at our next code meeting.
          I did it to code in Marin co., not SF. It all passed fine. I Knew this ,but never understood the reason. Be well Kevin
            I don't why....the reason given above I guess is as good as any....cause it don't make sense...that is why we do it? LOL!!!
            Derek
              We're all just trying to survive out there!
                Same reason they want fixture traps even if you have a whole house trap, the longer pipe runs can get fouled and start to smell. Now what keeps the smell from just pouring out of the open end when not in use? /shrug danged if I know.
                "This is how it was explained to me anyway"
                  We cannot go that far here before a trap on the indirect line. Why do you need it? The answer is contaminates making its way into the sinks. Where did they pull the numbers from? Who knows but that is the reason.
                  A floor sink is not a floor drain. They are common in restaurants and other food prep type areas. IPC requires 2" air gap.
                  AllurePlumbing.com
                  • leak detection
                  • drain cleaning
                  • utility locating
                  • conductor fault locating
                  • and other specialties.
