Florida BFP Page Title Module
  • Florida BFP
    Just wondering why in warm climates the BFP are installed outside. It seems they would be wy to easy to tamper with even when chained up. I live In a 4 season environment so we install them indoors (heated)
    Re: Florida BFP
    The further you get from the meter the more likely someone will make a connection in front of the device. In addition, consider the cost involved in a leaking RP indoors.
    "Somewhere a Village is Missing Twelve Idiots!" - Casey Anthony
    I never lost a cent on the jobs I didn't get!
      Re: Florida BFP
      I see what your saying we are only aloud to use DC units for that reason and installed down stream of the meter. Do you guys install expansion tanks as well inside?
        Re: Florida BFP
        My X-tank is just outside on the main, but many are inside on the water heater down here(Florida).
          Re: Florida BFP
          That boggles my mind a little. Is it above ground or in a pit?
            Re: Florida BFP
            When I lived in Florida...all the well components just sit on the ground including a shallow well pump....if it was going to be cold enough to freeze all you did was put a light bulb on it and throw a bed sheet over the whole thing.....cause be 8 am everything would be warm enough again...
            Poor Planning On Your Part Does Not Constitute An Emergency On My Part!!
            You can fire me...but you can't tell me what to do!
            Derek
              Re: Florida BFP
              Above ground, fastened to the house.
