Urinal Augers
    Re: Urinal Augers
    for those who pull wall hung urinals and then snake them,,,,,,,,,,,,,,,,that is the easy part of the job,,,,,,,the fun really begins when you have to re-set them and have no leaks,,,,,,,,,,,,,,,,,,,,waste and water,,,,,,,,,,,,,when you are a residential plumber you dont always remember to stock those parts on your truck,,,,,,,,,,,,,,,,example 2'' urinal gasket,,,,,,ben told u can use putty or wax,,,,,,not shure about that one.,,,,,i did use a toilet tank to bowl gasket ,,,once and it did work,,,,,,the flush valve connection can be a pita without new gaskets,,,,,but a couple raps of teflon tape you can get u out of a jam,,,,,
      Re: Urinal Augers
      Cheesehead. A tank to bowl gasket is pretty standard for the urinal seal. Though on a good solid flange putty works fantastic
        Re: Urinal Augers
        I tried a general urinal auger. Never could get it to work. The bulb auger does not do too much on the hardened build up. I pull the urinal and clean it with calci solv. Then snake the line with a 3/8ths cable with a cutter.
          Re: Urinal Augers
          why pull the urinal when using calci solv.,,,,,,or do you pull them when the calci solv fails,,,,
            Re: Urinal Augers
            Calci solv doesent fail, I think they use it for the urinal and then cable the drain.
              Re: Urinal Augers
              I use the General Urinal Auger. Last only a few jobs, kinks easy, but it does what it is suppose to do.
              Will Rogers Plumbing
              Moore, Oklahoma
              405) 323-2852
              www.willrogersplumbing.com
                Re: Urinal Augers
                I call my friend Tony and have him take care of it. I don't ask how, just how much.
                • #23
                  Re: Urinal Augers
                  Hope Ridgid isn't wasting R & D time on "improving" the urinal auger.
                  What we really want is a cordless version of the K-45, or similar.
                  The battery technology has evolved. Just need to adapt a drill motor to the task.
                  The key will be making it brakeless, so the drum can spin down when you let off the trigger.
                  • #24
                    Re: Urinal Augers
                    Agreed that be sweet.... Or a cordless toilet auger...that would be sweet....
                    • #25
                      Re: Urinal Augers
                      I`m looking at this thread and trying to imagine what the hell is a urinal auger and then go to goggle its a glorified toilet auger and a load of crap as I bought a ridgid toilet auger many years ago used it once and hung it my garage where all my failed tools are where they are collecting dust and I can sell them off to some unsuspecting moron in the years to come
                      Tony
                      • #26
                        Re: Urinal Augers
                        Toilet augers a must in the truck.. who wants to pull the toilet everytime.. all though they can be a pain in the ***.
                        • #27
                          Re: Urinal Augers
                          Please check your Private Messages. Thanks! Josh
                          • #28
                            Re: Urinal Augers
                            I try to clean the pipe so I don't get called back for awhile. So instead of snaking through the urinal which restricts the size of snake I pull the urinal and go directly into the drain.
                            • #29
                              Re: Urinal Augers
                              I use the General extendable urinal auger. It takes a little practice to get it to work. Their extend button is hard to use half the time you end up pulling out some of the cable from the drain, then when you extend it the tube the handle is attached to is out of the guide tube making it a bit more tricky to work. So I would make the inner tube a little longer even though it means when seated into the outer guide tube it will stick out an inch or so.
                              BTW I have two on my truck one for urinals the other for bar drains that drain to a floor sink. It works awesome for those short runs.
                              • #30
                                Re: Urinal Augers
                                Geez, I could get by with a Power spin equipped with the lockable auto feed of the kwik spin.
