hard to make money?
  • hard to make money?
    So drove out north today small community about an hour away. Homeowner tried doing GIS own finishing and didn't take any of my advice so I fixed his leaky sinks leaky faucets and leaking cast iron tub, drove another twenty min threw in a couple frost free hosebibs. Went to next job replace toilet and repair leaking pressure tank. Go to replace compression stop. Thats right tight, to the new cedar Wayne's scotting take nut off to find oakum, no pharoah the realise it was soldered on and the nut was done up so go to grab my btank, then the fun starts pull on my Lenox btank was stuck on a roll of wirsbo and bang the brass that connects the regulator to the tank snaps off and breaks doesn't look fixable ...fkuc dammit.... There goes any profit for today... So any reccomendations what you guys are running as far as btank set ups.. guessing your all using turbo torchs?
    Re: hard to make money?
    Put the B tank in the shop and went with the smaller size ...Running a Goss Hand piece
      Yah i got a small lenox mapp gas torch, it does most stuff but i like my b tank... Still run into lots og copper dwv and prefer b tank, but the mapp torch does most og my small stuff just fine. Thanks.
        Lenox mobile torch. Have an extra if you want it.
          Take your regulator of your tank while transporting it, then only put it on and take it off at the jobsite....
          Problem solved
            Every time I break out my B tank, I get tired of lugging it around, and swear it's time for something smaller. I actually carry 2 B tanks on my truck.
              After some research I think I can just get a new reg and adaptor mind you with my propress the btank doesn't get as much use but I like it regardless.
                I'm using probably a 75 year old Presto-lite
                  When I was running my shop in L.A. I used two wheel welding carts to carry my b tanks on along with a 15lb CO
                  Fire Extinguishers that way my jman could not complain about lugging around those tanks,
                  But they also used the small mapp torch's as well, also because of running out of gas at 5m on a Fri
                  my partner and me added a second tank so as soon as one was empty it would be left at the shop for
                  a refill so the guys always had plenty of gas for big jobs or complete house repipes
                  JERRYMAC
                  E-MAILJERRYMAC777@GMAIL.COM
                  FIRE SPRINKLER CONTRACTOR,
                  SINCE JAN. 1989
                    I am glad to see another die hard for using the B bottles. If you have to but a new regulator, forget using the adapter and just buy a regulator that fits the B bottle valve. I use the B bottle and I don't need an adapter....
                    The next size smaller bottle is a MC size but, that has a different valve than the B...
                      I carry two B tanks on my truck. When one runs out I start up the other tank, and the next day I swap out the empty for a full one.
