3 Handle Valley shower valve diverter issue?
  • 3 Handle Valley shower valve diverter issue?
    I started to rebuild a 3 handle Valley shower valve today. The hot and cold went in fine but I can't get the diverter stem in all of the way. It sticks out about an 1/8". Is there a trick to getting the rubber end to push all of the way into the valve body? Thanks for any help.
    Re: 3 Handle Valley shower valve diverter issue?
    try turning the diverter stem counter clockwise or if that doesnt work turn the stem the other way,,,,,then you should be able to screw it in all the way befor it bottems out,,,,,,,,,,,,,
      make sure no parts of the old washers or other debris are stuck inside the valve body.
