Ok, Rinnai issue......
  • Ok, Rinnai issue......
    Water leak above unit. Water got inside cabinet but did not seem to get board wet. Repaired leak and rebooted controls. Unit fired and on the first try stayed ok. Turned water back off then on again and stayed lit about 30 seconds then kicked off/locked out but no trouble codes. Did this in repeat but would do same each time. Suggested to leave unplugged and see if drying it out with a fan would help. If not, any suggestions?
    Re: Ok, Rinnai issue......
    Have you got a test point for your gas so you can check pressure. Over here they can be a little like a woman, a total *****. Need to make sure pipe size is also correct.
      Thanks. I called the customer yesterday and it dried out and has been heating since
