Is this possible
    Re: Is this possible
    Originally posted by plumber rick View Post
    ben, it was your daughters birthday today, were you out working?
    Rick.
    No Rick , Ben took Her fishing !
      In Australia we do not soft solder anymore, so if we have to silver solder near a soft solder joint we would heat it up and silver solder the joint,
      I guess it is capillary attraction that takes the silver solder through the joint, I have never had one leak at a latter stage,
      Simon
        Cut the fitting out and redo it.
        Can you cut out he fitting and redo as Mark suggests...?????
        Could you get one of Ricks pro-press tools in ???????????????????/
          Thanks but, dastardly hole !
            Simon
            THANKS , So You are silver soldering over a soft solder joint with success ?
              Tool I have actually done this. However reading this forum you will probably struggle as we use the old flux and I think you guys have to use the new DOLPHIN friendly flux. Rick is always saying it is not easy to use So I have to take his word on this. What I remember is that you heat it up and try to melt the old crap out and then flux up to the max. Use 5% or 15% silver solder, don't use the poverty pack crap 2%. I have done it so it shouldn't be too hard. Then again..........................!!!!!!!!!!!!!!
                Yes no troubles, just heat it up and let capillary attraction do the hard yards.
                We don't use any flux just silver solder, I use 5% but I have mates that use 2%
                Simon
                • #23
                  Leaked fixed . Silver solder to the rescue ! I googled silver soldering over soft solder. Great article about the Navy doing the same on large copper lines ! Thanks all , I am a "GOOGLE HOAR "
                  • #24
                    I have a rosebud tip on my Oxy Fuel torch setup that says I can melt whatever I want.......
                    • #25
                      Don't forget, I'm also a welder
                      • #26
                        I know, that is what worries me
                        • #27
                          Simon
                          Simon
                          I know it costs a bit more but try the 15% Silver Solder. Just be a bit more frugal with it. Clean your copper well and it will surprise you too. Got some good tips for cleaning the copper too if you want
                          • #28
                            Call me lazy... cut the old fitting off with a hand hacksaw right at the edge of the joints. Sand down any solder residue and propress a 90 on. It's almost a perfect fit.
                            Ben I have one joint , that after 20 Minutes It will grip occasionally ! Drained down twice and re soldered. I also, use My wet vac to purge out any water ! Driven Me nuts . Of course I'm using 95/5 solder. Question, would it help to go over the joint with 50/50 solder ,because of the low melting Temp. ? Thanks Tool
                            • #29
                              OK, " GENO IS LAZY " I like the excitement of 780 F cherry red copper, next to 50 Year old dry fir framing ! Keeps a Guy on His toes !
