Shower valve , customer request
  • Shower valve , customer request
    While traveling in Europe they liked this feature. There was a separate slide control for the Temp. setting.
    Who has this please ? Tanks Tool
    Re: Shower valve , customer request
    Thermostatic valve have dedicated temp control. Can you be a little more descriptive of "slide"?
    If not, how about a clue to where she saw these valves?
      In this age of smartphones, hard to believe they came home wanting one and didn't at least grab a photo of it.
        couldnt find a 'slide' version but did find this interesting contraption with a digital controller:
        Mira Platinum BIV Rear Fed - High Pressure: Digital Showers: Products : Mira Showers
          Have your customer take you to Europe to see it first hand.
          Most higher end thermostatic valves have a seperate temperature control. Some have numbers with the degrees marked others don't.
          I like grohes line of valves.
          Rick.
            Delta has one that has a separate temp and volume control.
              As does Moen
