Old Bronze Valves
  • Old Bronze Valves
    I was working on a kitchen faucet where, in the cabinet below, the supply stops were old gate valves. They are about 40 years old. One valve, the cold side, leaked very badly from where the gate shaft entered its packing nut.
    The valve was constructed as such:
    body < top half < gate shaft packer < main packer < handle
    I figured a little tightening would do it but found out that the threads were corroded out. Of course, adjustment made it worse and there wasn't time for replacement. (will be done next week) I figured cleaning it and a little silver braze would stop the leak....sooooo....
    Cleaned it up all nice and bright. No matter how hot I heated the damn thing, even cherry red, the silver wouldn't stick. It would ball up and run off.
    Is this common with bronze valves? Brass is normally easy to braze.
    I did stop it eventually by pulling the handle, stem, and both packers, then filling the remaining threaded hole with a 'silver plug'.
    Re: Old Bronze Valves
    I would have soldered it over braze. brass usually requires brazing flux. copper doesn't.
      Unless there was something special about the valve if the valve was 40 years old why not replace it?
        I would have probably replaced it too.
          Both valves are getting replaced. There just wasnt time then.
            punky i'm *** uming you had the water off, and the valves cleared of any moisture? as you know you cant heat water filled valves or get them to take solder when water filled.
            did you clean the brass really well? I've soldered brass many times and with the right temp and clen fitting it can be done.
              The water was off, the parts being brazed were outside and sitting on a concrete curb. The metal was polished and there was no corrosion anywhere. There was another type of brass I couldnt braze too. That was on a frost free spigot.
                Probably yellow brass, not much copper in it, cheaper than red brass.
                  Ice cream container underneath and lots of towels. Yeah good move to swap out for new.
